ONE TOUCH WINDOW SWITCH STOPPED WORKING WHEN I CHANGED BATTERY
Old Feb 26, 2006 | 03:51 PM
miishmiish's Avatar
4th Gear
Default ONE TOUCH WINDOW SWITCH STOPPED WORKING WHEN I CHANGED BATTERY
Hi guys, I am new to the forum, and to Ranges. I got a '98 and the battery went sour ever since I had a new stereo installed. I bought a new battery from autozone and now the one-touch window open/shut feature stopped working. If I want to open or close the window, I have to hold the switch down the whole time. Is this an easy fix/common problem?
Thanks so much, Adam
Old Feb 26, 2006 | 04:24 PM
esaycho's Avatar
Default RE: ONE TOUCH WINDOW SWITCH STOPPED WORKING WHEN I CHANGED BATTERY
If you get a message like Anti-Trap or One touch needs to be programmed when you are opening or closing the window, hold the switch down until the window is completely open then immedietly back up until it is closed and it should reprogram it. repeat for all windows and the sun roof
Old Feb 26, 2006 | 06:02 PM
miishmiish's Avatar
4th Gear
you were right on the money. thanks for the quick reply!!
Old Feb 26, 2006 | 07:20 PM
esaycho's Avatar
no problem
tsuyoi
Sep 22, 2020 10:37 AM
caneraiser
Oct 27, 2012 07:35 AM
ZB-30
Nov 18, 2011 06:54 PM
