Window Trouble
Rear driver's side window has always given me a bit of trouble. I had to click it down and then up to put it up and closed. So this morning, it is not going up at all. I try my trick and goes but stops halfway up. The thing aint budging. I tried the fuses, switching them, trying the replacement. No luck. So tomorrow's forecast is thunderstorms and really do not want to tape a trashbag to the window. Any suggestions? PLEASE!
year? is the motor whirring? Take the panel off and check the regulator. The plastic wheels that go inside the channels break often. Try to pull the window up using your hands. If it does go up, but wants to fall back down, use a couple of screw drivers (carefully) to wedge it up until you can replace the regulator
twoxred
10-04-2021 07:07 AM
Dan_da_LR3_H2_man
06-03-2009 04:05 PM
