windscreen washer - jets replacement
Old Dec 14, 2016 | 01:10 AM
KlamathMatt's Avatar
Default windscreen washer - jets replacement
i snapped off the plastic nipples that connect the washer hose to the washer jets last summer. i am just now getting around to replacing the jets that shoot water on the windscreen.
when i activate the front washers, i do not hear any motor. i also dont see any water coming out of the disconnected hose from under the bonnet. My front wipers work and the rear wiper and water jet works. Could someone please offer some advice on what i should check?
Thanks!
Matt
Old Dec 14, 2016 | 04:30 AM
Luckyjayb's Avatar
The headlamp washers won't come on until a certain criteria is met. The ignition has to be on in the II position, headlamps on, and then it only does it every third time.
Old Dec 14, 2016 | 04:32 AM
Luckyjayb's Avatar
I forgot to mention that the you can buy both nozzles with the hoses that attach to the one way valve behind the grille from lucky 8 realitively cheap. It's only a few buck more than just the nozzles themselves
Old Dec 14, 2016 | 04:34 AM
Luckyjayb's Avatar
Refer to the bottom of the page under headlamp wash. Hope this helps
Old Dec 14, 2016 | 06:38 AM
Charlie_V's Avatar
I must have misunderstood the OP. I thought he was referring to the front windshield nozzles rather than the headlight nozzles.
Old Dec 14, 2016 | 06:46 AM
Luckyjayb's Avatar
Hell I think I read it wrong. I guess that's what happens at the time of the morning. My bad
Old Dec 14, 2016 | 06:56 AM
mollusc's Avatar
OP -- did you check that the hose is still connected to the reservoir bottle behind the fender? Mine came off at one point and I spent ages trying to track down splits and disconnected wires.
Old Dec 14, 2016 | 07:04 AM
Luckyjayb's Avatar
Default Sorry for the confusion caused on my part
Op- sorry for the misunderstanding on my part. It looks like you can check fuse number 19 to see if it is blown if not here are a few pages from the rave on what to look for and how to access the windscreen pump again somsorry for the misunderstanding on my part
Old Dec 14, 2016 | 10:09 PM
Thanks for this info! I've been tending to my flu-ridden family all day. This info is helpful...i did confirm that my headlight washers are still functioning...and my original post referred to an issue i was having with the windscreen jets. i will check fuses and connections. Thx!
Matt
mln01
Sep 21, 2022 05:53 PM
bif
Sep 27, 2012 01:36 PM
yallie
LR4
Aug 7, 2011 08:23 PM
egb
Freelander
Nov 27, 2008 03:14 PM
mdm2297
Jun 19, 2007 10:36 AM
