Windshield Replacement
Old Sep 28, 2010 | 05:41 AM
d2luvr's Avatar
Had my heated replaced a couple months ago for $1200. They even called my insurance to make sure they would pay for that expensive a repair. Just under the max.
Old Sep 28, 2010 | 08:49 AM
'BamaBoy's Avatar
Originally Posted by BackInA88
I just had a new heated windshield installed for $342 and they were able to reuse the old molding, they were only going to charge me $85 if they had to replace it.
Safelight quote me almost $800.
Steve
Who did you have replace it? I'll keep them in mind for next time
Old Sep 28, 2010 | 07:31 PM
adwarren78's Avatar
Default Adding a heated windshield
I do not have a heated front windshield but noticed that there are two unused plugs on either side of the windshield on the front cowl. Is my truck prewired just like my front seats. If it is how do you turn it on I am guessing by the defrost button. I noticed my side rear glass looks like it is heated as well is this hooked up if I don't have a heated windshield. What about the mirrors I thought I read somewhere that the cold weather package came with heater mirrors as well. What would it take to convert my nonheated to heated mirrors
Old Sep 28, 2010 | 08:32 PM
bikingteacher's Avatar
The side windows are not heated on any of the Rovers--that is your antenna.
Old Sep 28, 2010 | 09:18 PM
lordmorpheus's Avatar
Yes, the unused plugs on the cowl are for the heated front screen option. Pre-wired, just like the heated seats (if you have the leather package). On the models with the heated front screen option, there is a button either just above or just below (I don't remember) the heated rear screen button. It has a similar look to the heated rear screen, but the image on the button is rounded at the top instead of flat like the rear screen heater button. Mine doesn't have this option so it just has a blank where the button would go. You could purchase a heated front screen and button, but, I believe, you would need to have the BCM reprogrammed to allow function.
As per Bikingteacher, the wires in your rear side glass are antennas- one side AM, one side FM, I believe.
The mirrors: I can neither confirm or reject whether they only came with the cold climate package. My owner's manual is for a 2001 (even though it is a 2000 (previos owner probably lost the original and bought something close from EBAY)) and it states:
the door mirrors have integral heating elements which disperse ice or mist from the glass. These will operate in conjunction with the heated rear window.
However, the manuals on Rave for 2001 and 2002 state: In some markets the door mirrors have integral heating elements which disperse ice or mist from the glass. These will operate in conjunction with the heated rear window.
In both manuals, this is not asterisked (as is the heated front screen as an option), so I really don't know. I guess the easiest way to tell would be to take an IR thermometer to the mirrors before and shortly after turning on the heated rear screen, to see if the temperature increases.
Old Sep 29, 2010 | 04:59 AM
BackInA88's Avatar
A place call "Mr Windshield" it's over by me in Clinton Twp. Just north of Detroit.
Steve
Old Sep 29, 2010 | 07:40 AM
Epixman's Avatar
8th Gear
Sorry for the thread jack OP,
Can you always replace your heated windshield with a non-heated one? Since it is much more expensive?
Old Sep 29, 2010 | 10:37 AM
yloDiscoII's Avatar
Yes, just make sure whoever does it wraps the heated windsheild plugs with electrical tape or something, to protect them in case you want to go back to the heated windshield later on.
I just had mine replaced with a non-heated a couple weeks ago.....got a rock chip 2 days later
Old Sep 29, 2010 | 06:05 PM
'BamaBoy's Avatar
Steve
Thanks Steve!
LR2driver
LR2
Oct 21, 2014 04:52 PM
toofaroffroad
Jan 23, 2013 02:44 PM
e24kgold
Jul 13, 2010 11:36 AM
Chrisinhouston
Nov 30, 2009 09:01 AM
Benhamtroll
Apr 21, 2009 05:31 PM
