Wiper fuses?
Old Feb 6, 2012 | 08:09 PM
ChefGabe's Avatar
Default Wiper fuses?
Hello
I took our 2002 Disco off road yesterday (pics soon) and now my wipers don't work at all. I am hoping and assuming that it's a fuse issue. Also, if anybody could point me in the direction of which fuse, type, and location that would be great! Any thoughts or suggestions would be appreciated, as always
Cheers,
Gabe
Old Feb 6, 2012 | 08:16 PM
The fuse box is under the steering wheel by your knees.
There is a diagram that shows which fuse is what.
Old Feb 6, 2012 | 09:16 PM
And underhood fuse box has fuse 4 (washers) and a relay that could bounce loose on potholes. Under dash be sure to look at fuses 19 and 26. See attached pix of wiper motor and connector in case you want to go that far.
File Type: pdf
Old Feb 6, 2012 | 10:54 PM
ChefGabe's Avatar
Cool! Thanks fellas! I'm sure this will do the trick.
Gabe
Old Feb 10, 2022 | 05:19 AM
macutan's Avatar
As i am researching an issue with my wipers and fluid liquid not starting at all after a freeze storm i came across your post and posted picture (pdf) can I ask you where did you get this from? Thanks in advance
Old Feb 10, 2022 | 08:29 AM
mollusc's Avatar
You're not likely to get a response from someone who hasn't posted on this forum in almost nine years.
ogden45
Dec 29, 2008 08:29 AM
dgee03
Nov 20, 2008 05:59 PM
MoNtErover
Sep 27, 2008 08:27 AM
OxyCoRover
Jan 27, 2008 09:56 AM
The Capstone
May 11, 2006 12:57 AM
