Wipers Don't Work, Radio Doesn't Shut Off With Key
Old Sep 14, 2012 | 08:06 AM
Street Wolf's Avatar
Arrow Wipers Don't Work, Radio Doesn't Shut Off With Key
These are at least the only two issues I've noticed so far. As of yesterday after changing a rear turn signal bulb, my wipers no longer work and the radio does not shut off when the ignition is turned off. Help?
Old Sep 14, 2012 | 08:37 AM
Antmen's Avatar
Do you have anything plugged into your cigarette lighter port? Mine was doing something similar when I had my cell phone or GPS plugged in, it wouldn't turn on the dome light until I pulled it or waited a minute or so. Almost as if it was giving me mercy power after shutting down the truck.
I'm probably way off, but weirder things have happened.
After that, I removed, cleaned, and rebolted any ground wires I could find.
Old Sep 14, 2012 | 12:26 PM
Thats odd, but nope, nothing in my cigarette plug.
I just can't think where to begin searching for the issue when this began simply after changing a light bulb.
Old Sep 14, 2012 | 01:09 PM
Bkreutz's Avatar
You could try removing the bulb that you just replaced and see if the functions return. (I've seen the radio not turn off with the key when the rear radio control switch was unplugged).
Old Sep 14, 2012 | 01:13 PM
bballjames's Avatar
I hope I'm not insulting anyone, but did you check all your fuses and relays? Both under the steering wheel and under the hood?
If the radio is staying ON though, you probably have a short somewhere in the accessory wire that tells it to turn on/off. Electrical problems like this are the worst. I had a fried wire to my cigarette lighter and it made all sorts of funky things happen. Hopefully you won't have to rip everything apart to check all the wiring...
Hopefully Buzz will chime in... he's seems quite knowledgeable about the electric systems of these trucks.
Old Sep 14, 2012 | 01:45 PM
Antmen's Avatar
Maybe someone might know if there's a TSB related to the ignition switch/steering column?
Old Mar 25, 2013 | 12:22 PM
usaborn's Avatar
I have a customers 01 Disco with the same problem, wipers don't work, radio wont turn off when key is turned off and seat heaters don't work. I printed out a wiper wiring diagram and saw that the Auxiliary Circuits Relay was on the page so I swapped the ABS and the Aux relays and everything started working again, so I replaced relay and all is well.
Old Mar 28, 2014 | 09:48 PM
bosshogt's Avatar
Street wolf did you figure this one out? It is a Relay in the underhood fuse box. Took me a awhile but I had this happen about 2 years ago. You can buy it at NAPA. I'll reseach the relay and model numbe if you need it.
Old Mar 28, 2014 | 10:35 PM
Yeah man, I got it figured out. Much appreciated though.
Old Oct 10, 2023 | 08:11 PM
macutan's Avatar
Hi, I seem to be experiencing this same issue. Radio remains on after I remove the key from the ignition and I need to manually switch it off, also I notice that the newly installed GROM remains transmitting the Bluetooth signal after key is out too. Would you happen to know what relay I need to replace? Also is a relay one of those big blocks that are located in the fuse compartment under the hood?
Any guidance will be greatly appreciated!
UPDATE: Been doing research today about this Relay, is it the Ignition auxiliary circuits relay (#7) ? (I have highlighted it in the PDF file; left part of the electrical circuit diagram).
File Type: pdf
Last edited by macutan; Oct 11, 2023 at 01:08 PM. Reason: added Electrical Circuit Diagram
tom999w
LR2
May 5, 2023 10:03 AM
Tomzsix
Mar 26, 2021 08:39 PM
photocrimes
Feb 20, 2011 08:05 PM
rocko12
Jan 27, 2009 06:56 PM
domyo
Aug 27, 2008 06:26 PM
