Wire assm 7-4 pin apadter trailer towing
Old Apr 9, 2013 | 02:40 PM
mark d's Avatar
Default Wire assm 7-4 pin apadter trailer towing
I found this part at Rovers North. "wire assm 7-4 pin apadter (their spelling) trailer towing"
WIRE ASSM 7-4 PIN APADTER TRAILER TOWING
I called but there was no one there.
I have the trailer plug down at the hitch. I could plug this part in and I am assuming I am ready to go? Are there electronics in this harness or can I just go in behind the plug and splice into the wires that lead to the plastic housing? With solder and heat shrink, of course. Thanks!
Old Apr 9, 2013 | 02:49 PM
nychaze's Avatar
There is no need for a LR specific one...you might be able to get one locally at wal-mart or more likely at a place that sells trailers/hitches.
Or order one that is cheaper than that over priced one on roversnorth
Just a quick search...look around:
7-Way Round Pin to 4-Flat Adapter Tow Ready Wiring 118709
Make sure you get a 7-way ROUND pin to 4-flat. NOT 7-way FLAT pin...
Old Apr 11, 2013 | 11:45 AM
mark d's Avatar
Default Reading the Etrailer questions
I don't think that adapter will work. I was reading the question section below the link you have and i found the following. Unless I am reading it wrong:
Question:
Does the 7 pin round mean that it fits a 12N type European trailer plug?
asked by: Bob S
Expert Reply:
No. The 7-Way end in the # 118709 adapter is made for the North American style of 7-Way round pins. A European 7-Way, see picture, has separate turn signals and brake lights and a circuit for fog lamps. The tail lights are also separate.
You would need to fabricate a special adapter to get the 2 to work together. I would need to know which end has the European 7-Way, the vehicle or the trailer. It would also require a semi-permanent change to the connector on the vehicle or possibly the trailer too.
expert reply by: Michael H
Old Apr 11, 2013 | 11:50 AM
mark d's Avatar
This further confuses me:
Recommendation for Converting a Euro Style 7-Way to a Standard 7-Way | etrailer.com
Do I need one of those converters that join the turn signals with the brake circuit? Will that work with the Rover's electronics?
Old Apr 11, 2013 | 12:07 PM
nychaze's Avatar
Aaaah, good catch, sorry for the miss information...damn European design!
I would give Rover North another call, it says they have the adapter in stock.
Im finding conflicting information on the splice route...let me search some more.
Old Apr 11, 2013 | 12:10 PM
drowssap's Avatar
this might help, and I might just confuse you more
Can a European 7-Way Trailer Connector be Converted to a U.S. 4-Way | etrailer.com
Old Apr 11, 2013 | 12:18 PM
nychaze's Avatar
Splice Route:
Is there a European 7-Way to US 4-Way Trailer Wiring Adapter for a BMW | etrailer.com
You will need this ($40) to make it work:
Roadmaster Brite-Lite Wiring Converter Roadmaster Accessories and Parts RM-732
Or go with this ($109............):
Land Rover Trailer Wiring Kit (Same Fit As Genuine Part # HIL-734)
Simplest and cheapest:
Trailer Connector - 7-Way European Round To Flat-4 Conversion Plug / Harness - Land Rover trailer wiring kits & harnesses from Atlantic British
I think rovers north had it cheaper...call them or get on Atlantic British...you can chat with them while you browse.
Old Apr 11, 2013 | 01:03 PM
jdwilks's Avatar
I didnt have the 7 PIN european harness ready to go on mine just had the empty harness behind the passenger taillight where I assume that would be hooked up at? I used the Hopkins 46155 Taillight Converter Universal Kit and just spliced/solder into the wires I needed and works just like it should for about 20 dollars. I also bought a mount for the 4 pin adapter and mounted it to the rear bumper so I didnt just have dangling wires
I used this link for wire colors
http://www.discoweb.org/trailerwire/index.htm
parkerlander
May 31, 2014 11:59 AM
Shark59
May 4, 2013 09:33 PM
ashtoo
Oct 7, 2011 02:45 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
Silver_Slug
Jul 18, 2010 10:21 AM
