Wires ripped out ..
Old Dec 21, 2023 | 10:33 AM
protonmailrover's Avatar
Default Wires ripped out ..
.. is this as bad as I think .. what is this ... DIY? ..parts to buy ? M and S lights are flashing .. Mobys in limp mode ..
o2 sensor 1 rear
wire near gearbox
wire near shield
wire near
wire sheath ripped up
Pic
how do I replace this DIY ?
Old Dec 21, 2023 | 12:09 PM
L33DiscoII's Avatar
Looks like a mouse was in there. That sucks. I'd cut out the damaged wires and solder in new ones with heatshrink shielding. I'd seal the ends of the heatshrink with liquid electrical tape or RTV. That's a really crappy place to be soldering, for sure! Good luck!
Old Dec 21, 2023 | 12:47 PM
Discorama's Avatar
There are easy to use soldering joints which come with heat shrink for that. You don't need a soldering iron.
Amazon Amazon
Old Dec 21, 2023 | 01:36 PM
No. Too many cats. Please no more talk about mouse. This forklift damage or other.
Back to my original question. What are these wire parts numbers ..where to buy.. is this a DIY...
I am out in the sticks there is nobody to help. How do I get this fixed.
Old Dec 21, 2023 | 01:39 PM
No solder. I don't know how to solder. Im too old to learn. I want plug and play DIY...What are these wires near the tranny, gearbox .. part number .. is DIY possible ..
Rove ris in limp mode. its not getting out until this is fixed.
Old Dec 21, 2023 | 02:23 PM
Richard Gallant's Avatar
There is no plug and play it is the vehicle wiring harness it is a repair job. Solder is it or the no solder connectors that is it.
If you have limp mode you can drive it, not fast but it will drive. And it looks like animal damage to me.
Old Dec 21, 2023 | 03:03 PM
Originally Posted by Richard Gallant
There is no plug and play it is the vehicle wiring harness it is a repair job. Solder is it or the no solder connectors that is it.If you have limp mode you can drive it, not fast but it will drive. And it looks like animal damage to me.
Not animal damage. It's from a ForkLift.
How many MPH in limp mode ?
Do you need a shop or can I do this in the field ? IS this the part ?
https://www.ebay.com/itm/18448802567...Bk9SR9zA7-CRYw
Old Dec 21, 2023 | 06:14 PM
mollusc's Avatar
That is probably the part, but that's a hell of a price to pay for something that will take a LOT of work to install. You will probably need to pull the centre console from inside the truck and remove the shifter plate to get to the top of the transmission.
The top photo looks like it may be one of the O2 sensors, which could even plug into a whole different harness.
Old Dec 22, 2023 | 02:48 PM
miron's Avatar
For 822 bucks you can buy a whole another disco and take the wire out od that, lol
Old Dec 22, 2023 | 05:10 PM
NEW CODES
Fault Code NA - Signal Too low - Intermittant
P0161 - Rear O2
P0141 - Rear O2
P0135 - Front O2
P1000 - Lambda Sensor Upstream
P0134 - Lambda Sensor Upstream
P1000 - Camshaft Sensor Fault Valve Timing Error Drive Cycle A Signal Invalid
P0102 - Mass Airflow Sensor Fauly Drive Cycle A
P0449 - Purge Cannister Vent Valve/D Power Stage Fault Crive Cycle C
PXXXX - Permanent Voltage Supply Fault Drive Cycle A
P0445 - Cannister Purge Valve Fault Power Stage Drive Cycle C
M and S lights still flashing ... and Now the ACE Fault Light, Service Engine Soon Light, and SLS lights are on ...
please tell me what is happening to my Rover .. why are there more codes ? I checked under and behind the glove box .. checked the engine bay .. everything .. and there are no other ripped out wires. But there are new codes ..
