Wiring help needed on 98 LSE
Old Apr 2, 2005 | 11:50 PM
asmcmillin's Avatar
Default Wiring help needed on 98 LSE
I am hoping someone can help me out in suggesting where I can tap into the electrical system to add a hot-all-the-time cigarette lighter. Any suggestions? Is there anywhere around the seats where I can tap in?
Old Apr 4, 2005 | 01:25 PM
hoberock's Avatar
Default RE: Wiring help needed on 98 LSE
The obivous choice is the battery. Actually, there is a screw post in the main fuse box (right next to the battey). You'll have to pull the cover off then the large fuse cover to find. You can thread the wire thru the firewire. Don't forget to add an inline fuser near where you tap into the battery. Good luck.
Old Apr 4, 2005 | 02:04 PM
mikemeyer0's Avatar
you could tap into the fuse box under the dash.
Disco(vering) more problems
Jul 21, 2014 11:35 PM
rovingmad
Jul 14, 2013 11:48 AM
Rover Curious
Jun 17, 2009 08:01 PM
samsly
Audio/Visual Electronics
Oct 27, 2008 02:30 PM
asmcmillin
Apr 10, 2005 12:16 AM
