Witts end!! Wont unock..
I think my truck is super locked but cannot figue how to unlock it. I have tried an new actuator, new battery in the fob, checked the fuses, tried the inertia switch. How do I check my fuse box and which one do I need to check? Under the dash or in the engine? What am I looking for?
Neither the fob or the interiot switch work to open the car.. only locks. Only the driver door unlocks using the handle. No other door will open. Thanks!
Im going crazy here!! I have searched a bunch, but cannot find anything that works!
I can unlock the driver door using the key but that is it.. I got a actuator but when I hooked it up to the cable to test it, nothing different happened.. Driver side will lock, and the others sound like theyare locking, but nothing unlocks...
I did have a problem in the past with the back cargo door not unlocking... could this be affecting anything? It happened a couple of times the never again..
I think you mis understood me.
Or maybe I am mis understanding you.
Have your wife stand outside the truck, you climb into the passenger seat and pull up on the door lock, NOT the door handle but the little thingy that moves up and down to lock/unlock the door.
While you are holding that up have your wife try and open the door from the outside.
I have the exact same problem. Happened last night as I was leaving work to head home (Great way to start the weekend). Anyway, I had mine (04 Disco) towed to the dealer (after my wife brought me the spare key / remote to try - no luck). The tow driver & I left it right in front of the service door so I sould hear today what the problem with mine is. I will post a message once I get some definitive info.
