Wobbly crankshaft
Old Jan 25, 2025 | 03:17 PM
04disco2v8's Avatar
6th Gear
Originally Posted by 99TEXASD2
Some questions:
What is the "clunking" sound that you hear that corresponds with each time the crank is moving off center?
Just listening to the cranking without watching the video...it almost sounds to me like you have a dead cylinder (compression wise). That cranking should sound like: nah, nah, nah, nah, nah, nah, nah, nah, nah, nah, nah, nah (steady & consistent (equal force needed to push each cylinder against the compression cycle)) but yours sounds more like: nah, nah, nah, nah, nah, nah, nah, NUH, nah, nah, nah, nah, nah, nah, nah, NUH.
I'll be honest if you have done a head gasket and you have a slipped or slipping liner, it could have already beaten the head gasket to death again and you now have a dead cylinder (again)....same exact thing happened to me on my old 03 I think it managed to last a month or so before it did that to it....ended up having to get a salvage motor that was good (heard it run from cold to fully up to temp listening for slipped liner - they usually can't be heard from cold start but can once warm unless they are REALLY loose) and totally rebuilding it and pinning the liners to make sure it wouldn't happen on that one.
Sorry for the late response, I’ve been busy with life. I’ve visually inspected each cylinder liner, but can’t find any that look different from the others from beneath. I will try and put it all back together and do a compression test to see if it has a bad cylinder.
emille26
Oct 6, 2020 12:40 PM
thatbaldguy
Nov 29, 2017 03:13 PM
pkppunk
Sep 24, 2013 06:14 AM
shanechevelle
Jul 9, 2013 03:11 PM
Jawbox
Feb 12, 2009 01:32 PM
