Won't fire after running ten minutes
Old Oct 29, 2008 | 04:25 PM
JLEONE's Avatar
Default Won't fire after running ten minutes
After sitting overnight my Disco II will start and run fine. As soon as I shut it off it will turn over but not fire. I have to leave it sit for 1 hour then it will start and run fine until I shut it off and it won't start again for an hour. I have no dealer for 100 miles in my area and most repair garages won't even trouble shoot my 2000 Disco II. Any help would be greatly appreciated. Thanks, Joe
Old Oct 29, 2008 | 05:27 PM
Default RE: Won't fire after running ten minutes
Joe, next time it wont start remove a spark plug and then reattach the spark plug wire and then turn the truck over and see if there is spark.
If there is no spark then it is your crank sensor.
You can get one from www.atlanticbritish.com
Old Oct 29, 2008 | 10:32 PM
tacomatech's Avatar
Due to the fact that it runs for a few minutes then dies and will not restart until it cools, I wouldn't even bother with the spark check. Just like GM, the crank sensor gets hot, resistance multiplies and as a result, no signal is sent to the pcm to provide fuel. Get a friend to help you with this: Take the cover off of the engine compartment fuse box. Locate the fuel pump relay. Have a friend turn the key on while you feel and listen to the relay for a "click", then turn the key off, repeat to verify clicking of relay. Then turn the key on, wait for about 10 seconds to let fuel priming elapse, then have your friend crank the engine over and check for the click as soon as he starts cranking engine, no click at start of cranking= no signal from crank sensor to pcm, which in turn leads to no fuel pump operation. Do this check when vehicle will not start. If crank signal is present, then check the fuel pump itself, and then check spark.
Old Oct 30, 2008 | 08:49 AM
discoxd's Avatar
i had a boat motor that did pretty much the same thing... it had a blown head gasket... hopefully this is not your problem too..
________
Live sex
dbishop
Jan 4, 2013 08:00 AM
vashonrovermechanic
Sep 21, 2011 02:50 PM
AuZZZie
Jun 9, 2011 11:25 AM
Rovercountry
Mar 22, 2006 03:38 PM
