Won't go into High gear.. Can't find solenoid
Old Dec 4, 2017 | 07:07 PM
cobbcj7's Avatar
Found small shaving of metal on the drain plug... Assuming this T-case is now junk.. Will pull inspection plate tomorrow..
Old Dec 22, 2017 | 03:35 PM
cobbcj7's Avatar
Question
My shifter thing will not go all the way into Hi gear.. I am underneath and it seems a little loose and is not fully engaged like the one in your picture..
How can I manually make it lock in gear from below??
All gears are lined up and look good.. I see no damage of any kind in there
Attached Thumbnails Won't go into High gear.. Can't find solenoid-20171222_155654.jpg
Old Dec 30, 2017 | 11:23 AM
cobbcj7's Avatar
Figured it out.. The dog callar shaft/rod was not lining up properly as we put the parts together.. I kept the inspection plate off, and used a pry bar to hold it in 4 High as we put it together.. Now it holding fine.. not going to shift it for a while.
HammerFit
Sep 18, 2018 02:23 PM
jad568
Freelander
14
Apr 15, 2013 02:47 PM
twaszak
Jun 27, 2011 01:32 PM
jalbright2000
Dec 30, 2010 07:05 PM
KBW
May 23, 2010 03:35 PM
