Won't run
Old Mar 14, 2013 | 06:40 AM
Mike4's Avatar
Default Won't run
I have a 2001 disco ll when I push the gas paddle it die out change the fuel pump and mass air flow do any one have an idea what it could be
Old Mar 14, 2013 | 07:33 AM
drowssap's Avatar
So you now have fuel preasure at the fuel rail?
Old Mar 14, 2013 | 09:14 AM
Throttle Position Sensor - unplugged (it will work on stored default value) or bad (values can be seen with a scanner). Fuel pressure would be good to know, but getting to that test point is not very easy.
Leak between MAF and engine (un-metered air). Blocked air filter?
Any engine codes present? If no code scanner, a parts store usually will read for free, write down the numbers and post back here.
Old Mar 14, 2013 | 12:21 PM
Do you have any faults code numbers, if so what are they?
Submariner
Aug 13, 2015 09:22 AM
m3dragon
Feb 24, 2015 10:08 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
thecardoc
Dec 13, 2010 08:56 PM
baddiscoII
Jan 11, 2009 12:10 PM
