Won't Shift Into Low - Fixed
Old May 9, 2015 | 11:25 AM
gmad's Avatar
Default Won't Shift Into Low - Fixed
I was having trouble shifting from high to low gearing (the differential lock was working fine). Searching about it, seems like the general consensus was either clean it out or a faulty solenoid - which is an annoying fix.
Definitely explore the idea of cleaning out the linkage. You can see the connection from under the vehicle and are just barely able to get some cleaner sprayed up there. My method of attack was PB Blaster, Parts Cleaner, WD-40.
After about 30 minutes in between each soak, it shifted into neutral and then low gear without problems (while running, in neutral, slowly rolling helped).
I've read that it is recommended to shift into low fairly regularly regardless of need. I hadn't for over six months, but plan to exercise it several times a month moving foward.
importdave
Sep 25, 2014 10:18 PM
Ringo
Jul 26, 2011 11:59 AM
KBW
May 23, 2010 03:35 PM
NiteTrain
May 14, 2008 08:43 PM
discotx
Dec 22, 2007 10:08 AM
