Won't start!
Old May 23, 2011 | 09:02 AM
Jason Smith's Avatar
Default Won't start!
Starter is is working but engine wont start....where to begin?
Old May 23, 2011 | 09:26 AM
dgi 07's Avatar
try the usual suspects first.
1. Battery Voltage
2. Fuel pressure and fuel cutoff switch
3. Spark.
then report back.
Old May 24, 2011 | 02:09 PM
Ok here we go.... voltage ok, fuel pressure ok but had to bench test it. Something has shut down the fuel pump and the spark. Could it be something with the alarm system? Did find that the wiring has been spliced in the back quarterpannel????? i need a schematic of the wiring harness to see what they have done....anyone got one?
Old May 24, 2011 | 02:50 PM
dcarr1971's Avatar
Have you tried resetting the inertia switch on the firewall? If there's no spark and the fuel pump is off, then this is the next thing I'd check...
Old May 24, 2011 | 03:51 PM
mwindth's Avatar
Try this courtesy of jafir: Microcat - Spare parts Land Rover catalogue in English
Click on Land Rover Microcat...
Old May 25, 2011 | 06:31 AM
Yes, the inertia switch was one of the first things i tried. Didn't make a difference. I was reading back on some old posts and found it could possibly be the crankshaft sensor.
Old May 25, 2011 | 07:00 PM
dgi 07's Avatar
ok....before you go replacing parts un-necessarily, get a code reader. pull the code.
and how did you test the inertia switch?
Old May 26, 2011 | 08:19 AM
Had it towed to my mechanic yesterday. No codes appear.
I didn't actually test the inertia switch, I just tried to reset it.
Old May 26, 2011 | 08:24 AM
humroot's Avatar
It's your Crank Position Sensor (DII). Mine just went and I had the same symptoms and NO codes. It was $70 at Advance Auto.
Old May 26, 2011 | 09:59 AM
Just picked one up. Hopefully that is it.........for now!
