Won't start!
Old May 26, 2011 | 02:01 PM
Jason Smith's Avatar
Up and running. Crankshaft sensor was out. Thanks for all the help.
Old May 26, 2011 | 06:45 PM
humroot's Avatar
Excellent!
Old Jan 28, 2016 | 01:48 PM
Amir_S's Avatar
Default Land Rover won't start or crank
Hey guys I'm in a bit of a situation here. I'm not sure why but my Land Rover won't turn over or even crank but the battery is fine. I've jumped it and have it hooked up to a battery pack but still nothing. I'm pretty sure it's the starter but I thought I'd make sure first. Can anyone can help?
Old Jan 28, 2016 | 01:59 PM
Alex_M's Avatar
Try smacking on the starter with a hammer or something and then see if it will start. That should get it to start. Might even work a while like that, but if that starts it then you'll want to replace it. If that doesn't work then you've probably got another issue. Also check fuses.
Old Jan 28, 2016 | 02:00 PM
wjsj69's Avatar
Sometimes I accidentally hit my lock button on the key while turning it to start the truck, and the engine won't crank. I push the unlock button again and she's fine. The first time it happened I had a panic moment too. If that's not it, It could be the starter or a host of other things.. do you have a code reader? If not, you'll need it eventually, being a Rover-owner.. They're cheap these days:
Robot Check Robot Check
Old Jan 28, 2016 | 05:38 PM
cappedup's Avatar
Does it click? I'm guessing you have dash lights?
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
