Wont Start, Flashers Going
Old Aug 17, 2016 | 04:40 PM
LR03NJ's Avatar
Default Wont Start, Flashers Going
2004 Disco runs smooth and normal. following day wont start and flashers went on all the time. Car got immobilized. Not sure what caused it. Check forum for answers, tried all codes and technique but still not starting. Might have exceeded the number of trials I made. But, To have the car towed to dealer plus dealer rates will be way out of budget. Help needed.
My question:, if I replace the ECU and BCU, will it do the tick? Will I be able to start and run disco again? Any suggestions? Thanks
Old Aug 17, 2016 | 05:56 PM
Racer X's Avatar
Inertia switch, located under the hood against the firewall.
Push it back down.
So long as it's not defective, the 4 ways should stop flashing, and the truck should start without issue.
Old Aug 17, 2016 | 06:11 PM
toofaroffroad's Avatar
If you replace the ECU, it will have to be reprogrammed to sync with the BCU. this is a 10 second easy job for the proper engine computer tool. An LR specific mechanic should be able to do it.
If you put another ECU in without doing this it will not start.
58ford
Jul 13, 2011 06:07 AM
happycamper
May 4, 2010 02:01 PM
Darover
Sep 18, 2008 09:49 PM
Brad S1
Apr 21, 2008 04:33 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
