Wont stay running
Old Apr 5, 2012 | 11:58 AM
lee698's Avatar
8th Gear
Default Wont stay running
Hi all,
I have a 2001 Disco; I just got it back from the shop twice in the last 6 weeks, once for head gaskets, once for a new thermastat. Now my latest issue, my rover will start when it cold, once I let it run for about 15 minutes it stops. if I wait about 5-10 minutes it will start again then stop. I have replaced the knock sensor but that didnt fix it.
Thank you in adavance,
Lee.
Old Apr 5, 2012 | 12:39 PM
Next time this happens, check for spark. No spark indicates the Crank Position Sensor on driver side rear of engine (NAS), sometimes you can pour cold water on it and it will reset. But once this starts, usually no adjustment. $70 or so part, tight place to work, will leave you stranded if not dealt with. If DIY, be sure all spacers go back on in exact sequence, spacing is hyper critical.
File Type: pdf
npayne
Sep 23, 2014 03:51 PM
Disco__Stu
Jun 18, 2014 09:36 AM
mooreshawnm
Jan 23, 2013 10:11 AM
Young
Nov 21, 2008 07:43 PM
soccerinco
Sep 29, 2007 03:43 AM
