Worn Rod Ends
Old Jun 5, 2011 | 07:22 PM
kenk's Avatar
Default Worn Rod Ends
Upon inspecting all 4 rod ends, I found 1 that has maybe 1/8" play in it. It is the one on the wheel end of the rod that goes steering box to pass. side wheel.
Would that be enough to cause a "loose" or "woobly"feeling while going over bumps or road irregularities? At first, I thought it was bad shocks, but found the bum rod end. BTW, steering stabilizer is brand new, and panhard bushings have zero play in them.
Old Jun 5, 2011 | 08:57 PM
Changed all four on my 97 D1, 172K; steering improved quite a bit, and was able to adjust drag link to level the wheel. I went with the zerk fitting ones from DAP Enterprises, I think it was about $70 for the whole set. In your area, the number of potholes can exceed the number of pine trees, so it might be time....
Old Jun 5, 2011 | 09:14 PM
kenk's Avatar
I did the same thing on my D1, all 4 from DAP. But all 4 needed replaced. Unfortunatly, my D2 has them funky rods that have one rod end stamped permanently in.
I have been debating getting the HD rods from lucky8, as the rod with 2 ends would still be cheaper than using O.E. design replacement parts, and I would not have to replace the whole rod if just the ends were bad.
Old Jun 6, 2011 | 09:56 AM
You will need to buy the long rod, which includes a built in tie rod. How are the rest of them holding up?
Old Jun 6, 2011 | 05:45 PM
kenk's Avatar
The rest are tight, but I am afraid if that one is starting to go(or gone), the rest are probably not far behind.
94svt50
Feb 18, 2011 08:55 AM
dynomite
Jan 25, 2011 03:39 PM
tweakrover
Dec 10, 2010 11:43 PM
bmwrovers
Jun 4, 2009 06:17 PM
ljdiscovery
Aug 4, 2008 08:57 PM
