Would i have to change driveshafts if....
Old Jan 21, 2008 | 07:35 PM
LRDISCO's Avatar
Default Would i have to change driveshafts if....
I put an OME heavy duty lift and some 1" spacers from atlantic british?
Old Jan 21, 2008 | 08:29 PM
okdiscoguy's Avatar
Default RE: Would i have to change driveshafts if....
You should be pushing 3" with that, and to my knowlegde, you should be ok. Watch the brake lines, though. I think you are on the edge of needing to extend.
Old Jan 22, 2008 | 08:44 AM
Up to 3"s you will be fine.
How maqny miles on your truck? If you are over 60K, you might consider replacing your rubber brake hoses with some new stainless steel line that will also help with the lift.
As for the drive shafts, all you need to do is have the front shaft rebuilt, if not already done, using u-joints with grease fittings in the double cardon.
What year is your truck?
collin Barrows
Aug 28, 2011 07:13 AM
mrcrptguy
Jan 21, 2009 11:27 AM
dirtymorgan
May 11, 2008 12:36 PM
Darover
Apr 2, 2008 08:06 PM
danelsis
Dec 6, 2007 01:25 PM
