View Poll Results: Leaking Head.
Voters: 20. You may not vote on this poll
Would you???
I'm sure there is some wear to the bores, but likely more to the old rings.
I need to look around some more.
If the bores in mine look good, and measure in spec, I won't really be concerned. But I would like to do it right, as well as knock off any carbon at the top of the cylinders.
Trying to avoid machine shop if everything measures good, as I think it will. Just re-doing everything while engine is out to pin cylinders.
Floors and things are rotted.
But its a daily driver and its not going to get better...
I have a ton of things planned for it in the next couple months, but I think I'd rather do them to a newer one.
Sounds like you have quite a list of maintenance to do. Anyone can understand how that can be overwhelming. But if you get another one, as already mentioned, it could need as much or more than what you have now. Maybe a beater is in order to buy some time to get everything done on the Rover with no pressure. Then you can unload the beater to recoup some $; look at it as a rental? Probably save some gas $ if you get a little 4cyl. toyota or whatever..
The devil that you know etc..
I know, but that's .005" too big, and half the size of the first over size bore of .010".
