X-case ?
Old Nov 28, 2009 | 02:39 AM
sloppyjoe's Avatar
Default X-case ?
was in the garage tinkering since the gutters in front of my garage were torn up and i could not leave the garage. so i rotated my tires, cleaned under the hood, cleaned the brakes, sprayed black rust killing paint on the rear passenger radius arm where a large rock has chewed at it and began to rust,,,also the bottoms of the diffs. cleaned and conditioned the leather. check for leaks and cleaned the pans for the engine and tranny. lubed the shafts and checked the A/C drains. the driver side was clogged and dripped out a small amount of water,,,
anywho, i am about at 55,000 miles and i still have the belt, P/S pump, tranny and X-case fluid swaps to do. my question is where is the fill for the X-case? i was feeling around and didnt find it,,, i know its buried up there somewhere that will be a pain in the ***,,, but where
Old Nov 28, 2009 | 03:24 AM
d2luvr's Avatar
As I remember it is behind the brake drum drivers side at 10 o'clock.
Old Nov 28, 2009 | 05:20 PM
Yup, back of the t-case, 10 o'clock on the parking brake drum is the fill/check plug.
Old Nov 28, 2009 | 06:29 PM
sloppyjoe's Avatar
ahhhh that explains it!
i was thinking 10 o clock, but i was laying on my back looking on the wrong side.
thanks douches
Old Nov 28, 2009 | 07:07 PM
No problem Bevis.
Old Nov 29, 2009 | 07:52 PM
grussell's Avatar
Here is a picture.
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
