XYZ Switch Repair Misery
Old Oct 23, 2015 | 07:38 PM
04duxlr's Avatar
Default XYZ Switch Repair Misery
So my DII started doing the dreaded M&S flashing thing. I had the battery tested and it was bad so I replaced it hoping that would be it. No such luck. I tested the voltage at the battery with the truck running and it was 14.2 volts so I decided to pull the XYZ switch. First the head of one of the bolts sheared off while I was removing it. The bolt was seized within the slot, surrounded by a nice white mass of corrosion. Then when I went to loosen the nut on the selector shaft it too sheared off. I had sprayed it liberally with PB Blaster but it was rusted on there pretty solid.
After pulling off the switch, I was able to get the remaining portion of the broken mounting bolt out but I can't do much with the selector shaft. I opened up the switch and there was a discolored contact so at least it needed to come off. I cleaned it up nice and shiny and bent it back into alignment so hopefully it will work again if I ever get the thing back together.
So now all I need to do is fix the selector shaft. I don't want to pull the valve body and replace the shaft so I'm thinking I can pull up the carpet, core a hole through the floor next to the selector shaft and drill and tap it for a bolt to hold the shaft on. The flats on the shaft that keep the arm from turning are still intact so all I need to do is keep the arm from falling off the end.
Anybody else had to deal with this? Is there a better way?
Old Oct 23, 2015 | 10:18 PM
fellipe's Avatar
Just the flashing M S lights two days ago.
Changed the battery and it solved itself only after a drive around the block.. guess you need to give a little time for the ECU to clear the faults...
stu44mag
Mar 8, 2023 11:45 AM
meltdowndave
Nov 5, 2019 09:02 PM
meltdowndave
Apr 28, 2019 09:53 AM
RicknCody
Mar 28, 2010 07:49 PM
meltdowndave
Sep 26, 2009 11:18 AM
