XYZ or T-case neutral??? Help!
Old May 24, 2011 | 01:54 PM
hilltoppersx's Avatar
Exclamation XYZ or T-case neutral??? Help!
turned the truck off wen tto turn it on and got nothing but a single click with every key turn. battery is good and connections are good. i never had a problem shifting gears, reading gear selection on the console or shift lever. i ran a hot wire to the battery and turned the key and it turned right over. banging with the hammer didnt work as i realized it wasn't getting the low current it needed to engage.
is there a way to tell the difference between an xyz sensor failure vs a t-case neutral failure?
those are the two things i have come down to believing are the problem but do not feel like just throwing parts at it.
anyone?
Old May 24, 2011 | 02:41 PM
dcarr1971's Avatar
When installing my D1 CDL, I jostled one of the linkages on the tranny and had a similar problem. I figured that I had managed to throw the XYZ out of whack. In my case, I was able to undo the issue by adjusting the linkage.
Are you able to take the key out of the ignition? When this happened I couldn't. If the key is stuck, then my thought would be that XYZ switch is bad.
Old May 24, 2011 | 03:33 PM
key comes out freely.....
Old May 24, 2011 | 09:27 PM
If you turn the key all the way on can you shift out of park?
Old May 25, 2011 | 05:11 AM
good question, i think it did but i can't be sure. ill give it a try.
Old May 25, 2011 | 07:49 AM
Go get your charging system tested, I 'll bet your problem is there. Whenever you get a click, either you have a dirty/loose cable or low voltage which should be between 13.6 and 14.4 volts.
Old May 25, 2011 | 08:11 AM
voltage is good, battery is good, all the connections are clean and tight, alternator is strong running 14.2 i tested all that on the trail. i can get an XYZ from Will for $75 shipped with a year warantee but i just want to make sure that is the problem. I also saw someone used tubing to re-route the AC drain that drips on the XYZ switch, i know people take them off and drill them open and find them full of water so im guessing that is what will happen with me. I would hate to spend the $75 and find out that it's the tcase neutral switch instead.
Bobcat9024
Mar 29, 2022 03:36 PM
willieg
Jan 31, 2015 04:37 AM
kman35ca
Jul 31, 2012 08:02 PM
lordmorpheus
Jun 13, 2012 05:11 PM
