Your Ash ray and Coin Tray Stuck? Look Here. Fix Write up in side with Pics!
Old Jun 25, 2025 | 10:23 AM
  #51
H Hill's Avatar
Default A slight modification
Resurrect an old thread, but still works!! Remember on a 2000 Disco you have to remove both sides, 6 screws total, and carefully pull out the ash tray, drink holder and coin tray assembly as one unit. I was fortunate as only the left side was broken, so I could use the right side to confirm how the broken one was to go together. Took the time to lightly grease the tracks it runs out on and gave it a good cleaning/wipeoff.
I had to drill a small hole in the housing as the idea of a zip tie through the existing opening caused the zip tie to rub on the coin tray assembly as it came out, impeding its travel. The small hole for the zip tie did the trick. At least I know how to change it when the zip tie lets go! 😂🤣
Good to go!👍
Madlands
Sep 1, 2018 12:07 AM
zukijames
Apr 3, 2013 11:19 PM
keoni004
Mar 4, 2013 06:10 PM
aguison
Sep 25, 2012 07:10 AM
Camdisco24
ROAMING WITH FRIENDS
Jan 31, 2010 05:30 AM
