ZF Auto failure
Old Apr 23, 2013 | 07:26 PM
Baylink's Avatar
If I'd gotten to it before I sent it off to the shop.
In fact, I recently replaced the battery, and it sat without one for at least 6 hours, and the radio didn't lock up on me -- which is good, since I don't know its code.
What's that about the hood switch? That's a bit I hadn't heard before; could you expand?
Old Apr 23, 2013 | 08:17 PM
MuddMouth's Avatar
Originally Posted by jfall
I would find the transmission controller and see if you can clean up the CAN Bus connection.
Maybe get the radio code handy.
Then pull the battery cables off.
Put the cables together when they are off to clear all capacitors.
And reboot the controllers by putting the battery back on (With the HOOD switch disconnected).
Long shot.
But...
It is cheap to do time wise and costs nothing.
Then do the hoky poky and you turn yourself around... that's what its all about....
Old Apr 23, 2013 | 08:20 PM
Baylink's Avatar
I can't turn myself around.
My transmission's broken.
<rimshot />
Old Apr 23, 2013 | 08:33 PM
MuddMouth's Avatar
Brick
Old Apr 23, 2013 | 08:37 PM
Hood switch disconnect - then when battery dies, and you open hood to jump off, you don't end up waking up the immobilization function for the alarm.
Old Apr 23, 2013 | 08:48 PM
Baylink's Avatar
Oh, right, Buzz. I tend to forget about the alarm, since my horn doesn't work. I don't believe I've ever fought with the immobilizer. Maybe once, and I had to do the keyhole hokey pokey.
Old Apr 27, 2013 | 09:36 AM
Baylink's Avatar
So it wasn't the transfer case, and it wasn't the converter...
it was, it turns out, a bearing plate that separates two clutches. It apparently failed rather spectacularly, and let the two clutches grind against one another until they in turn failed, and it stopped moving. Parts $1k; labor $1.2k. <sigh>
Old Apr 27, 2013 | 09:52 AM
Attached Thumbnails ZF Auto failure-bad-mechanic.jpg   ZF Auto failure-wallet.jpg
Old Apr 27, 2013 | 10:27 AM
Baylink's Avatar
Well, thanks, Buzz.. that makes me feel so much better. :-)
In practice, though, when I got the truck for $4k, market said it was at least an $8-9k truck for it's condition; this repair brings me right up to that, over 4 years.
I guess I can live with that, for something that was $44k new, 8 years earlier. :-)
Old Apr 27, 2013 | 10:37 AM
It smelled your tax refund...... (or maybe one in a mailbox nearby)..
