ZF Auto failure
Old Apr 27, 2013 | 10:41 AM
  #21
Baylink's Avatar
I've been self employed for a couple years; I don't get a refund.
Old Apr 27, 2013 | 11:46 AM
  #22
So a business web address on the back glass makes this a business expense...
Old Apr 30, 2013 | 12:14 PM
  #23
Baylink's Avatar
Late update: they completed the repair, reassembled everything, and were ready to install it... and spotted cracking in the flywheel, at the bolt holes.
Are you sitting down?
The Aamco shop in question *is replacing the flywheel, at their expense*. Bought it from the dealer. Overnight freight. "We should have caught that when we disassembled it".
Hats off to the shop, which I will identify in a week, when the repair has held. :-)
Old Apr 30, 2013 | 05:21 PM
  #24
That is a surprise for sure.
Old May 4, 2013 | 12:53 PM
  #25
Baylink's Avatar
Alas, while they were standup guys about not charging me for the flywheel with cracked bolt holes they should have spotted, they can't seem to finish getting the rebuild to work properly.
They put it all together, and put it in, and in test drives, they couldn't get it to go into fourth until 55, and it would fall out again, much below.
So they tweaked the 3-4 shift solenoid, and eventually replaced it, and it still wouldn't, so they tore it back down, and found that one of the o-rings, in that part of the hydro system, had folded over. So they replaced and refitted, and readjusted...
and now it wont pull into 4th at all. He says he sees the shift command on the bus, but while the converter will lock, the 3-4 shift doesn't happen, and they can't figure out why.
Anyone else who's still listening ever have a ZF that wouldn't go into fourth?
(I guess all those people who've been telling me all day "may the fourth be with you" don't have the Force, either...)
Old May 5, 2013 | 02:39 PM
  #26
jfall's Avatar
  • Admer
    ZF 5HP24 no 4TH GEAR
    Hello, I'm hoping i can get some direction with this ZF 5HP24 on a 2004 L322.
    Vehicle drives fine with gears 1 through 3 but cuts out when it hits 4th gear. It will go into limp mode as soon as shifts from 3rd to 4th, pressing the gas
    pedal just revs the engine I have to do a shut off and restart to get the Rover shifting again.
    I've already searched the forum but can't seem to find someone with a similar issue :?:
    It acts up hot or cold and even in manual shift mode mode, it will shift fine from 1 through 3 but as soon as it hits 4 it looses gear.
    The shift solenoids + pressure solenoids + the speed sensors all check out fine and are in spec when ohmed from the connecter at the trans ecu.
    The High/Low switch seems to be working fine and fluid level has been checked and there are no shavings in pan.
    Codes that I was able to pull FROM THE TRANS are GEAR MONITOR 4 FAULT -GEAR MONITOR FAULT -STALL SPEED FAULT
    Any help is appreciated
  • November 21st, 2012, 04:36 AM
    RRPhil
    Re: ZF 5HP24 no 4TH GEAR
    That has to be a B-clutch problem, surely - especially if it won't failsafe into 5th gear either? Unfortunately I haven't come across this particular issue before.
    Phil
  • November 21st, 2012, 06:24 AM
    Admer
    Quote:
    Phil
Old May 6, 2013 | 10:47 AM
  #27
Baylink's Avatar
I gather, jfall, that that was a quote in reply to my inquiry?
I said "B-clutch" to the guy and he said "yeah; I suspect the new clutch may have a hairline crack in it that opens up when it comes up to temperature".
I missed a step in the story: it will go into 4th when *cold*, but not after it warms up. Since the clutch was part of the rebuild kit, it's his problem. As are all the fit/unfit cycles; I didn't realize that it takes 3-4 hrs to put that thing in and pull it out.
Old May 6, 2013 | 10:54 AM
  #28
Baylink's Avatar
And I read that whole thread... and I didn't know the 5HP24 was a *five-speed*; am I missing something?
Or was that poster misinterpreting 1-2-3-Lock-4?
Old May 6, 2013 | 11:31 AM
  #29
Baylink's Avatar
So, y'know, I feel like an idiot.
This transmission is (as I suspect some of you were polite enough not to make fun of me for not realizing) a 4HP22, not a 5HP24. :-}
Old May 6, 2013 | 08:25 PM
  #30
Baylink's Avatar
We have a semi-final answer here. My incorrect designation notwithstanding, it does in fact appear to be a hairline crack in the new B-clutch that was part of the rebuild kit; when it got up to temperature, it spread and started leaking pressure.
I'm supposed to have it back tomorrow afternoon.
