Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Gear shift delay and fault only develops when main beam is on
Old Nov 19, 2022 | 02:06 AM
Matty range's Avatar
Default Gear shift delay and fault only develops when main beam is on
Hello,
just joined this forum and hoping to get some out.
Mr range rover sport 2006 2.7 has developed a fault ...the gear wont until it its about 4500 revs abd problem only occurs during night drivibg when i use the main beam.
if i switch them off the car droves fine.
to date the following has been done
1.transmission case module changed
2..New battery
3.brake light switch changed
4.multiple diagnostics
5.Alternator tested
I read that this problem could be related to ground wire which I will be lookinglooking just wanted to know if anyone else has come across this issue and share there experience..most impottantly what was the fix?
Thanks
Old Nov 19, 2022 | 12:18 PM
Canuk's Avatar
Probably Best to post on the Range Rover Sport forum and not the Land Rover Discovery Sport forum.
Sking
Discovery Sport
Sep 1, 2024 06:11 AM
Scott C
LR4
Apr 25, 2023 05:09 AM
MacNoah1960!
Oct 26, 2022 06:56 AM
dajaguar
Range Rover Evoque
Jun 8, 2022 11:48 PM
dannyc
Feb 15, 2005 04:37 PM
