Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Mislock Warning - 2018 Disco Sport
Old Apr 5, 2023 | 11:25 AM
RedYoshiEgg's Avatar
Angry Mislock Warning - 2018 Disco Sport
Hi all, Owner of a 2018 Disco Sport HSE and am having an issue with the vehicle's locking system.
I noticed on our InControl app that the car was unlocked. Used the key fob to lock (one press), and noticed the side view mirrors did not fold in and the tail lights did not flash as usual. About 3 seconds after the lock, two short honks came from the car - I believe this is the LR mislock warning. Kept the key in our mudroom so keyless entry wouldn't interfere and checked all 4 side doors, each were locked and secure. Bonnet was tight, I felt no upward give. The trunk was closed and tight as well. I reopened all doors, bonnet, and trunk and closed them securely. Went back indoors and used the fob to lock again (one press) and noticed, again, that the side mirrors did not fold in and the car honked again with a mislock warning.
Today, I took the car to our LR dealer. Tech said all door latches and modules are functioning as expected, including the trunk. They performed some resets and unfortunately this didn't resolve our issue. The InControl app still shows the car is unlocked, and the key fob's lock button triggers the same mislock alert. Tested the doors and they are still locking despite the message. They mentioned we should order new door latches and modules and replace these to see if this resolves things (), but I'm skeptical replacing parts in working order just to see if this fixes it ...
Given the doors are locking, it's more of an inconvenience than anything (having to get the key fob away from the car, run back and check that it's actually locked). Does anyone have experience with this issue? Any ideas on how I can troubleshoot of fix? Some other notes:
  • Prior to the issue, I used to notice the trunk 'whirring' as it locked. An initial click once it was onto the latch, and a whirring noise as if the lock was securing it in place. I no longer here this whirring noise but apparently there is no issue with the trunk
  • Key fob battery is new - It's not a faulty fob
  • Car is basically new - we've got just north of 30k miles
Old Apr 5, 2023 | 12:35 PM
Canuk's Avatar
Open all your doors, trunk and hood. Then give them all a hard slam to close and then test. I had that problem and it was the hood that needed a hard shut, not a gentle touch
Old Apr 5, 2023 | 05:14 PM
Thanks! Tried this before, and once again at your recommendation. Unfortunately, this didn't resolve things Any other ideas?
Old Nov 15, 2023 | 10:05 PM
ptbronco's Avatar
Did you ever resolve? I am having the same issue on a 2017 Discovery.
Old Oct 14, 2024 | 04:14 PM
jlkalousek's Avatar
Default 2019 Discovery Mislock
Here to report the same issue. When I lock, I get a double honk mislock and mirrors don't fold. Doors lock. Hood and trunk closed. Issue started after I had body work done after a minor accident to my passenger doors. Hoping someone has found a solution.
Old Nov 10, 2024 | 02:56 AM
Kotor's Avatar
Hello, I got the same problem, did anybody fixed it ?
By mine it is depending of temperature, when is warn inside is ok, when is cold inside shows unlocked Rear right door.
Jamie2202
Nov 29, 2023 06:50 PM
Cecil Trent
Nov 26, 2019 08:27 PM
gc3
May 16, 2019 12:13 PM
engin70
Nov 2, 2016 11:14 PM
greenwade
May 6, 2010 02:17 PM
