Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
no start code p0a0f
Old Jun 19, 2023 | 02:35 PM
CLBowman's Avatar
6th Gear
Default no start code p0a0f
Hi all. My 2016 discovery sport 2.0 refuses to start. It has code p0a0f "engine failed to start" and p0615 "starter motor relay-circuit malfuntion". The engine does start, so I have disregarded the second code so far. Any ideas what could cause this? I am suspicious of a sensor somewhere, but not sure. Maybe crankshaft sensor? Any suggestions appreciated!
Old Jun 21, 2023 | 09:27 AM
CLBowman's Avatar
6th Gear
found it. At this point, it appears that the timing chain slipped off of one of the cams. I don't have the front cover off, so it may be broken but I was not able to pull it out.
Now the question is what should I be watching for while doing this job? I understand that there are some updated parts like guides and tensioners? Should I change anything else while I am in there? At this point I am planning to do the timing chain, oil pump chain, all tensioners and guides and the vvt actuators.
Also I am aware that this is an interference engine. At this point, I think I got insanely lucky. Only one set of valves are down, and only a little bit. So far, I can't see any signs of damage there. I am planning to get my bore scope to the car next week and will scope out all cylinders before I decide that they are ok.
TCKellogg
Discovery Sport
Sep 10, 2020 06:08 PM
theautocollection
Aug 22, 2020 08:09 PM
fma01709
Jul 11, 2020 02:49 PM
golgafrinch
Mar 14, 2017 12:55 PM
snugg
May 13, 2008 09:19 PM
