leak up front, not sure what it is
Hey guys, I need some help.
I have a 1988 LR Classic. It's had some work done to it . But it's leaking oil, I think. I just had my timing chain changed and all my oils and fluids changed. After I am leaking some sort of oil, I believe its engine oil. It's from the front of the vehicle. It's a bit much for comfort but I check all my fluid religiously and they don't change? Any ideas???
If a Land Rover ain't leaking it is out of oil. I would guess steering gear or power steering pressure line. Actually if position of leak is relative in pic I would say front cover gasket or trans cooling lines at radiator.
