Engine & Internal Chat about beefing up your engine's insides here.
P38 Engine Problems
Old Jan 25, 2011 | 07:38 PM
enterusernamehere's Avatar
5th Gear
Exclamation P38 Engine Problems
Hi, I just finished replacing the dead 4.0L from my '96, with a lightly used 4.6 donated from a '98. I fired it up, but I encountered a few problems.
My first problem was, the engine temperature gage does not work. This is my first Range Rover, so I don't know where everything is on it. I'm pretty sure that the thermostat is on the Righthand side (Looking from the front of the engine), by the injectors, and the coolant bleeder valve, but i'm not sure where the thermostat gage sensor is. Is it not working because I maybe don't have it hooked up, or maybe it's a fuse?
And my final problem was, every time I step on the brakes, the ABS warning light, along with the traction control light, and the emergency brake light comes on.
My Questions are:
1) Where is the thermostat gage sensor?
2) Is there, and if so, where is the fuse for the Temp gage?
3) Is the warning light for the brakes the computer, or did I disconnect something, and forgot to hook it back up?
15degreeGTI
Jun 18, 2013 12:49 PM
toxoscar
Apr 2, 2011 03:49 PM
coleman1
Feb 17, 2011 04:43 PM
d.weglarz13
Jun 12, 2010 10:49 AM
red rockett
Sep 4, 2008 01:27 AM
