Engine & Internal Chat about beefing up your engine's insides here.
re-ring one cylinder?
Old Jun 23, 2007 | 08:26 AM
Erik's Avatar
Default RE: re-ring one cylinder?
Well thanks Mike you are giving me hope! Ill let you know what I find when I get the heads off.
Thanks again.
Old Jun 25, 2007 | 09:41 AM
Erik's Avatar
Hi Mike, I did a leak down test on the low comp cylinder, Its giving me a 80% leak and im hearing the air pressure escaping in the valve covers. Would that be a valve or ring /sleeve issue?
Thanks.
Old Jun 26, 2007 | 08:22 AM
Time for a valve job.
Mike
Old Jun 26, 2007 | 08:55 AM
Erik's Avatar
I have the heads off, im taking them to a machine shop today to have them checked out. The sleeves inside the block look fine, is there a way to visibly see if one has dropped? While everythings apart I guess i should inspect everything for peace of mind.
Thanks again.
Old Jun 27, 2007 | 08:16 AM
Just make sure they are all sitting at the same level and you don't see any cracks.
Mike
Old Jun 27, 2007 | 04:42 PM
Erik's Avatar
Will do thanks.
Old Mar 25, 2008 | 07:05 AM
CandiMan's Avatar
It's been awhile, I'mcurious how this turned out.
scarrell
Nov 16, 2012 06:04 PM
1stevereynolds
May 20, 2009 01:26 PM
xb70valkarye
Mar 31, 2009 01:31 AM
tuwrx
Mar 26, 2008 07:26 PM
