Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
5.3 LC9 engine / 6L80 trans.Discovery 2
Old Apr 4, 2026 | 01:57 AM
  #71
Techno's Avatar
Originally Posted by mohammed
Hello, how can I activate the XYZ safety switch for the 4L60 transmission to make it compatible with my Rover Discovery 2? My second question is, can I replace the Rover's ECU, and if so, what systems will I lose if I do so, since I will be using an LS engine and transmission? Thank you all.
First, have you found a transferase adapter and transferase that will work with 4l60?
On the xyz switch im not sure how it compatible or not with discovery BCU. Check rave manual and service manuals for Both. so see what will work. D2 xyz switch Conects to BCU.
Replacing ecu you will have to work on : cruise control, a/c on off, hill descent control, traction control, maybe some more. I can't think of them. Hopefully someone can reply.
what generation LS engine ECU?
Old Apr 19, 2026 | 11:30 AM
  #72
mohammed's Avatar
7th Gear
Default Connector C0637 ECU p38 2000 details table. Can you help me by sending the pin inform
[QUOTE=Techno;934409]هذا القابس ليس ضروريًا، لقد أضفته فقط. استخدمته لأني أريد نظام تبخير يعمل. أعتقد أنني انتهيت بصنع أسلاك جديدة من وحدة التحكم الإلكترونية لمحرك جنرال موتورز.
لم ألتقط صورة لهذا القابس. سأضيفها لاحقاً عندما أجد الوقت لذلك. [/QUOTE
whowa004
144
Sep 3, 2024 11:02 PM
Adesapigne
Oct 19, 2020 11:45 AM
Stu-Nyce
Mar 28, 2017 09:05 PM
clint70
May 17, 2016 08:15 AM
dannmary
Mar 4, 2016 08:06 AM
