Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
D2 LS Swap (ACE Swap) M&S Lights Solving Guide
Old May 26, 2025 | 07:13 PM
  #31
Miketee's Avatar
4th Gear
Default Anyone still checking this?
Thinking about adding ferrite to the crank sensor harness. Any thoughts, has it been tried?
Old Sep 24, 2025 | 05:25 PM
  #32
promptedsplash2's Avatar
Did this end up working? I am having the issue on my 04 LS swap one as well and before going through cabeling curious on this!
Old Sep 24, 2025 | 05:49 PM
  #33
Miketee's Avatar
4th Gear
Mostly. I ended up pulling the crank sensor harness out of the loom and kinda routed it away from the power cables coming from/to the starter and alternator.
side note maybe helpful I turned the crank sensor so the harness points toward the front. Ultimately I think moving the harness is the fix.
Old Sep 25, 2025 | 08:15 AM
  #34
I will have to try that when I have time! Glad it was able to work for you, for the time being I found I can apparently clear the code from the rover ECU while the motor is running and after cleared it drives as normal. Unsure if that is good or bad LOL
Old Mar 31, 2026 | 08:13 AM
  #35
mohammed's Avatar
7th Gear
Default How was the throttle valve screw slightly loosened to increase the throttle position
Originally Posted by 04disco2va
Issue Resolved - M&S, TC, Hill Decent lights. CaptainAaron thanks for the help again. So my mechanic focused on the TPS (WFPDK error) and found that the cause of this error was due to the GM TPS voltage being outside what the Rover side was looking for (see below). As I understand the GM TPS works from 0-5volts. The Rover side .195-4.83volts. According to my mechanic all that needed to be done to resolve this issue was adjusting the Throttle blade screw open some which brought the TPS voltage up within the parameters to make Rover side happy.
I’ve been driving for 4-5 days with A/C, lights, stereo on and not one issue.
How was the throttle valve screw slightly loosened to increase the throttle position sensor (TPS) voltage? Could you please help me with pictures, my friend, as I'm using a throttle body specifically for an LS?
betzdII
Jun 15, 2023 10:16 PM
Daniel Smith
Apr 3, 2020 12:13 PM
NinjaPlease!
Jul 31, 2019 09:03 AM
fikus555
Nov 14, 2015 06:48 AM
smittyrc
Dec 23, 2013 08:37 AM
