Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Disco 2 can you swap a engine with sai to an engine without sai
Old Feb 17, 2020 | 03:05 PM
Kinggarlic25's Avatar
3rd Gear
Default Disco 2 can you swap a engine with sai to an engine without sai
I have a 2000 Discovery 2 with secondary air injection could I put an engine without secondary air injection and still be able to pass U.S. emissions and drive the car right
Old Feb 17, 2020 | 03:23 PM
Sixpack577's Avatar
Depends on your state's laws.
If you don't change the ecu, bcu, dash to those from a non sai truck, you're going to get a check engine light, which will fail in most states.
If your state has the tailpipe sniffer(not all do)again depending on that state law, it will likely fail, but may pass based on it's age.
Also, strangely enough, the tailpipe sniffer is not required in all areas of the same state to pass inspection.
Here in Va it's the same standard test state wide, but the tailpipe sniffer is only done in the Northern Va area and not required elsewhere.
What state are you in?
Old Feb 17, 2020 | 03:24 PM
Sixpack577's Avatar
Also, the only engine difference is if the heads have the sai ports or not.
gatorm
Aug 11, 2017 04:04 AM
RoverRoman
May 6, 2017 08:20 PM
Hephaestus
Feb 28, 2017 07:58 PM
mule2ears
Nov 5, 2015 11:37 AM
aublec22
Mar 20, 2011 01:28 PM
