Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old 06-06-2019, 10:51 AM
Alex_M's Avatar
Originally Posted by 2002 beast
I'm wondering if we put High flowing race catalytic converters under their will that throw check engine light on the O2 sensors
Some will and some wont with the GM ECU. Its a mixed bag of results. That said, modern factory cats are still "high flow" cats. The high flow catalyst is by comparison to the old style cats from the 70s and 80s that were full of pellets. You won't notice any difference swapping out the cats. If you're going that route you might as well re-do your exhaust system to increase pipe size. Then you'll notice some difference.
  #382
Old 06-08-2019, 10:59 PM
losinov's Avatar
For those that only pulled the upper intake manifold and did not remove the heads from the block... what existing holes did you use on the block when attaching your block to an engine hoist and leveler? Normally I'd use the head bolts and an L bracket.
I'm thinking about removing two of the opposing corner bolts that hold in the inlet manifold and attaching the hoist diagonally across the top of the block (see pic below).
Also considering using one of the holes on the front of the block where the power steering pump bracket attached previously. If I go that route I'm not sure what to use on the back of the block as an attachment point.
12 bolts that hold down the lower half of the inlet manifold.
I'd use some hardware to attach the chains from the leveler to these two bolts.
Was also thinking about using these points that previously held on the front brackets and accessories.
  #383
Old 06-09-2019, 04:41 PM
Daedrix's Avatar
ACEngineer (06-09-2019)
  #384
Old 06-09-2019, 05:59 PM
ACEngineer's Avatar
Took the new install for a test drive today. Still have a few things to sort out -- exhaust leak and check engine light, but overall, seems solid.
The following 2 users liked this post by ACEngineer:
brmadsenad (06-12-2019), dozer2 (06-19-2019)
  #385
Old 06-13-2019, 10:34 AM
Robert Johnston's Avatar
5th Gear
really interested in this as I am approching 200K on the engine, rplaced head gaskets back around 85K an while not using water ahve started really using oil ( a qt between changes at 3K each change)
have completed form
thanks
ACEngineer (06-13-2019)
  #386
Old 06-16-2019, 11:31 PM
losinov's Avatar
Finally got the engine out! Now to find a new heart for Diego.
Front mounting points for the leveler. Used the 2 ton hoist from Harbor Freight on the 1/2 ton setting for the arm.
Rear mounting points for the leveler.
Old motor on the 750lb harbor freight engine stand. Attach the black arms and square to the engine first and torque to the numbers in the rave then slide into the red receiver.
  #387
Old 06-24-2019, 12:16 PM
stereophile33's Avatar
ACE...any updates on this? I've got a dying disco 2 motor that is hanging on....barely. Ready to do this!
  #388
Old 06-25-2019, 09:00 AM
perryr's Avatar
when can these kits be ordered? I tried calling the number on your website and left a couple voice mails with no return call
  #389
Old 06-25-2019, 05:16 PM
ACEngineer's Avatar
4 beta test kits went out today. We are estimating that the kits will be available late summer, as soon as we get feedback from this set of beta testers. Sorry about that, send me an email - it's the fastest/best way to get in contact.
dozer2 (06-30-2019)
  #390
Old 06-29-2019, 03:04 PM
ACEngineer's Avatar
Hello everyone,
I just wanted to send an update. More of the beta test kits have been sent out. This brings the total to 11 with another 2 almost ready. I’m looking forward to seeing how these installs go.
It’s almost been one year since the first video was posted and I just wanted to say thank you for all the support, especially from this forum. I know it has been a slow and long road. Bringing this project from a prototype to a kit has been a sizable effort, amongst the trials and tribulations, but the newest kits are markedly improved over the first prototype.
The latest kits improvements from over a year ago include: 0.25 inch shorter drivetrain length, redesigned motor mounts, and new electrical conversion box. These improvements have made the install a lot easier and the overall setup much cleaner.
More kits are on the way.
dozer2 (06-30-2019)
Quick Reply: Discovery 2 LS Conversion
