Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
P38 4.6 into 2003 Land Rover disco 2
Old Aug 9, 2020 | 11:08 PM
Mr. Tick's Avatar
Default P38 4.6 into 2003 Land Rover disco 2
What’s up guys, finally about to make the plunge into getting my truck with it’s new (used) engine from a 1999 Range Rover P38. 90k miles.... My beloved 2003 Disco 2 with 78k miles will hopefully be running soon *photo attached
im on a bit of a budget hence a used Range Rover engine but just wondering what I should let the shop know to change or keep an eye out for if anything about an engine swap like this,
I know these aren’t complicated engines but my truck has sat for about 16months waiting for this job to happen. Aside from normal new gaskets and seals and things like that Is there a big chance of things going wrong maybe electrically or if the Computer could have issues with the new engine?
the truck has been in a garage 90% of the time it sat although the engine bay is a mess, pieces everywhere from the failed rebuild it had prior
What do you guys think of my idea for a swap and thanks for any response, much appreciated
Old Aug 29, 2020 | 07:56 AM
keninnc's Avatar
I did the same thing this June. 2002 P38 4.6 into my 2003 D2.
No issues.
One note. The P38 has a different ground for the engine. I used the same ground for the D2 that is in the rear of the engine on the drivers side. It is the steel/aluminum looking flat strap.
I did use the upper intake manifold from the D2. I was nervous about throttle cable being tensioned correctly so this solved that issue.
In 1999 the 4.6 engine was an option. Even the HSE models would come with the 4.0 engine. Make sure it is a 4.6. If not you will need to get a 4.0 ECU for a D2.
Also, make sure you get new engine mounts. When I pulled my D2 engine the motor mounts were split and not reusable.
Old Apr 7, 2021 | 06:25 PM
nwaluke's Avatar
How'd the swap go? I'm engine shopping now for my '04 D2
Old Apr 15, 2021 | 11:03 AM
Mr. Tick's Avatar
still waiting but finally have some work started at the mechanics shop, he was going through some family issues, but all or most parts are ready and just a bit more waiting at this point
Mr. Tick
Jun 7, 2020 02:24 PM
TRIARII
Jan 17, 2014 07:32 PM
TRIARII
Jan 11, 2014 11:25 AM
meltdowndave
Nov 27, 2009 01:57 PM
MGMan
Apr 29, 2009 11:15 PM
