Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Stuck in first gear ¯\_(ツ)_/¯
Old Nov 1, 2024 | 09:38 PM
Jensen Vermont Stenberg's Avatar
Default Stuck in first gear ¯\_(ツ)_/¯
Ok hive mind, I need your help!
no flashing m&s lights
no amigos
“sport” mode “works”
shifter and dash show actual gear selection
in high range I only get first and reverse
However!
Low range manual mode I can shift through gears.
any ideas on what I should be looking for? I don’t have a nanocom, is this something that a reset or code clear on that would resolve? Appreciate any help!
Old Nov 2, 2024 | 05:07 PM
Been going over the connections on the ACE box, seems like I might have flip flopped a few of the throttle position wires going into the ACE box.
Old Nov 3, 2024 | 03:20 PM
CaptainAaron's Avatar
I think you are on the right track looking at the connections to the ACE box. If those were mixed up, I could imagine strange transmission behavior.
Old Nov 5, 2024 | 08:21 PM
Replying here for closure. TPS was wired in wrong. So apparently if you have TPS issues the rover will not shift out of first gear.
zero-one
Mar 28, 2021 04:34 PM
kmsvl7314
Aug 4, 2019 07:24 PM
DiscoDrew9
Jan 7, 2018 08:52 PM
Mr R
Oct 16, 2015 04:32 PM
jhill15
Dec 2, 2012 03:58 PM
