Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Disco4 totally locked out - how to open bonnet?
Old Nov 22, 2016 | 02:10 AM
landi's Avatar
4th Gear
Default Disco4 totally locked out - how to open bonnet?
I am totally locked out - yes, I do not have the "safety key" only two electronic keys...I need to open the bonnet/ hood I guess to get some live to my battery again. Normally the battery used to have minimal power to unlock the doors but today it is totally flat.
1) Could I remove the front grill (without too much damage)?
I pulled... and the lower part moved out...but the upper part seems to be screwed in somewhere, correct?
2) Is there a way to reach the wire through the grill, pull and unlock?
3) more suggestions...
Thanks a lot!
Help needed really.
Landi
Attached Thumbnails Disco4 totally locked out - how to open bonnet?-img_9602.jpg
Last edited by landi; Nov 22, 2016 at 09:25 AM. Reason: wrong category, sorry - want to delete here
Old Nov 23, 2016 | 04:56 PM
vonfrese's Avatar
6th Gear
Any luck yet? Seems one might remove the left wheel and drill a hole in the well body to get to the hood release. Then patch the area later so it might be used again someday.
Old Nov 30, 2016 | 05:31 AM
landi's Avatar
4th Gear
Thanks a lot! I finally relied on the Land Rover dealer getting me within 5 days a new security key. Problem solved! Battery seems to be a weak spot. LANDI
Quinn519
Jan 23, 2022 09:44 AM
tattoorich
Nov 7, 2020 05:05 PM
DiscoDoobie
Feb 10, 2011 10:10 AM
tattoorich
Dec 13, 2010 07:16 AM
