Freelander Talk about the Land Rover Freelander within.
03 freelander, temp gauge not working
Old Mar 13, 2012 | 06:15 PM
danguenard's Avatar
Default 03 freelander, temp gauge not working
hi ! i have a 2003 freelander 2.5L and my temp gauge does'nt work at all. i need a complete wiring diagram of all that concerns the gauge from the sensor.
Old Mar 13, 2012 | 09:04 PM
The full set of all manuals on your truck is in the document called the RAVE, free download link in my signature.
The Freelander has an engine coolant temp sensor that is monitored directly by the ECU that also runs the engine. A signal is sent from ECU to instrument package that will place the needle at mid point under normal operation. Could be a simple as sensor unplugged. Here are some pages from the RAVE to get you started, there is also some wiring associated with the instrument cluster in the RAVE.
File Type: pdf
File Type: pdf
Old Mar 13, 2012 | 09:20 PM
Should also mention that a scanner or ultra gauge can be used to read the temp from the OBDII diagnostics port, the ECU sends this in digital form. If scanner sees it, then wiring issues are ECU to gauge (including dash cluster). So a $60 Ultra Gauge may be a cheap fix.
Old Mar 17, 2012 | 12:12 AM
janepaul's Avatar
5th Gear
that's a nice stuff it would help me a lot thanks for the post...
tsuyoi
Sep 22, 2020 10:37 AM
Gazawood
Freelander
Apr 12, 2012 03:26 PM
collin Barrows
Aug 8, 2011 09:33 PM
ozmoto
Sep 10, 2005 01:07 AM
