Freelander Talk about the Land Rover Freelander within.
2005 Freelander V6 2.5L service manual
Old Mar 25, 2013 | 08:35 AM
JAIMELU's Avatar
In my signature are two links to RAVE, one is a large file download, and the other is a section by section download in pdf online. The Land Rover Manuals should work.
savannah buzz , thakns for your help on freelanders 2.5 manuals were great, greetings from puerto montt ,chile
Old Apr 26, 2013 | 05:57 AM
JAIMELU's Avatar
my 2003 2.5v6 freelander engine,after replacing intake manifolds gaskets, will not accelerate , idles only, my doubt is defective gaskets, cause didn´t match on the manifold side, there is a groove along de manifold that goes to base of injectors s.o.s.!!!!!
Old Apr 26, 2013 | 06:07 AM
JAIMELU's Avatar
relative to my earlyer post, somebody that wants to help, send me his e mail y could send pictures of the manifolds and gaskets that i have. manythanks
jaimelu (mine jaimemanriquez49@gmail.com
Old Apr 26, 2013 | 07:24 AM
Sounds like throttle disconnected. You have an electric throttle, which is controlled by an electric motor. The engine computer signals that, based on inputs from the accelerator position sensor. You could have a plug loose or jammed, so un-plug, clean, and reseat. Check associated fuses. Sometimes this sort of thing makes engine codes, so that may help as well. The shop manual is part of the RAVE document package, free link below.
In the old days, we stomped on the gas pedal and a linkage opened the butterfly valve on the carb and we were off to the races. Now you put pedal to the electrons.
Old Apr 28, 2013 | 06:21 PM
JAIMELU's Avatar
many thanks svannah buzz, will try that and I´ll see
Old Apr 29, 2013 | 06:32 PM
JAIMELU's Avatar
2.5v6 2003 freelander, still problems with it, there is anybody anywhere who can tell me about the intake manifolds gaskets won´t match on the manifold side because there is a groove on the base of manifolds, if you try to put it together will not match, if you still do it, will loose vaccum . , you have to have one phisicaly in your hands to see.
Old Jun 10, 2013 | 12:21 PM
JAIMELU's Avatar
hello savanah buzz, once more thanks for all the help, two things with my 2002 freelander 2.5v6, the front bank of cylinders won´t work, there is compression, inyection (fuel) and spark ok. I wander may be the timing but I can´t open your link for rave manuals for tyhe marks
many thank
Old Jun 12, 2013 | 05:24 PM
JAIMELU's Avatar
savannah buzz, finally y brought down another service manual for frlander 2,5v6 but nowhere can find a step by step to set the timing on camshafts belts , manythanks for some more info.
Old Jun 12, 2013 | 06:10 PM
page 248 0f 1007 in the workshop manual.
Mrmerlin
Apr 23, 2011 10:19 PM
finman
Mar 31, 2011 09:44 AM
bodyzoo
Jul 8, 2010 09:08 PM
geonuine
Aug 11, 2009 04:57 AM
wtsnt
Freelander
Oct 3, 2008 08:50 AM
