Freelander Talk about the Land Rover Freelander within.
Advice for novice!
Old Aug 26, 2007 | 05:00 AM
lifesabeach's Avatar
Default Advice for novice!
I have a 2002 FreelanderV6 ES which has developed a funny smell which appears after driving for a couple of minutes, doesn't matter whether you have cool air, warm air or air con on it is still there, I can only discribe it as a spicy smell??? Also checked oil and it's quite lumpy and rusty looking. Any advice would be welcomed!!
Old Aug 28, 2007 | 05:47 PM
okdiscoguy's Avatar
Default RE: Advice for novice!
just looking through here. How often do you change your oil?
You need to do a flush and change you oil bad. Then monitor all of your fluid levels
Old Aug 29, 2007 | 04:36 PM
Card's Avatar
3rd Gear
I would definitely change the oil. Lumps are always bad.
Also, the smell might be coming from your cabin filter for the A/C. Might not hurt to check and see if it needs to be changed out.
Old Aug 29, 2007 | 06:56 PM
Could it be a sweat smell, if so it is a coolant leak that should be checked ASAP.
OffroadNewGuy
Apr 13, 2014 09:21 AM
nateandnikki
Jul 2, 2013 06:38 AM
Sarge103
Jun 20, 2013 07:10 AM
TRIARII
Aug 29, 2011 06:55 AM
livingetc
Nov 24, 2004 08:30 AM
