Freelander Talk about the Land Rover Freelander within.
code p1475 help
Old Jun 8, 2008 | 03:21 PM
skeith223's Avatar
Default code p1475 help
I have a 2002 freelander with a 2.5 v6 and Im getting a p1475 code it also has hard acceleration and very hard shifts at times could anyone please help, it also has 70000 miles.
Old Jun 8, 2008 | 04:07 PM
roverguy7's Avatar
Default RE: code p1475 help
the code is for your vis motors, replace them as a pair, easy to do, should fix the accel problem, as far as shifting goes, they have big issues with the transmissions, and with that milage you need to get your timing belts replaced
Old Jul 7, 2011 | 11:39 AM
whizzkid's Avatar
5th Gear
Default P1475
i have a similar problem ie code P1475. I NEED TO ASK, WHAT ARE VIS MOTORS AND WHERE ARE THEY LOCATED
Old Jul 7, 2011 | 11:20 PM
rtonder's Avatar
Both are mounted to the upper intake manifold plenum. Take off the silencer cover, and you will find them on the plenum near the coolant tank. They have one electrical connection and mount with four screws. The one nearest the tank and mounted vertical is the balance motor. The one closest to the front of the vehicle is the power motor and controls the annoying power valves which often come loose from the control arm and rattle inside the manifold.
Old Jul 8, 2011 | 02:36 AM
whizzkid's Avatar
5th Gear
ok thanx
hatt53
Mar 27, 2013 05:16 PM
mpompliano
Freelander
Dec 28, 2012 11:49 AM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
