Freelander Talk about the Land Rover Freelander within.
Exciting project: 2001 Freelander KV6 engine swap with Toyota 7A-FE engine
Old Mar 28, 2018 | 10:43 AM
Kimani's Avatar
Default Exciting project: 2001 Freelander KV6 engine swap with Toyota 7A-FE engine
Due to persistent overheating, I've decided to drop the failed KV6 engine of my 2001 Freelander 2.5 V6 and pop in a 120hp Toyota 4-cylinder 7A-T20C. I have seen a few (6) Freelanders having had this swap and running fine, most having swapped the entire drive train to Toyota (front wheel drive only) automatic transmission.
I prefer to retain the Steptronic shift and the all-wheel drive of the Freelander. So I wish to retain the original JATCO JF506E gearbox and swap only the engine, harness and ECM but retain the original ETU ECU & ABS system & ECU. However, I have a concern;
How complex will it be to integrate the signals between the systems?
Old May 20, 2021 | 11:15 AM
Francisco Guzman Sanchez's Avatar
hi kimani i will like to do the same swap as you did you get it to work and i will like you to tell me the process please.
Old Aug 13, 2021 | 11:57 PM
Special's Avatar
I was looking fir a good conversion too.
Fberschauer
Freelander
Jul 23, 2023 04:19 PM
entrus10
Freelander
Oct 19, 2019 06:29 AM
teddyz
Oct 30, 2013 11:55 AM
03se3
Engine & Internal
Oct 26, 2009 05:28 PM
slainiae
Freelander
Oct 5, 2007 10:22 AM
