Freelander Talk about the Land Rover Freelander within.
Freelander 2005 A/C drain hose
Old Aug 29, 2021 | 03:21 PM
BC freelander's Avatar
4th Gear
Angry Freelander 2005 A/C drain hose
Hello - I cannot find the drain hose on my Freelander 2005 for the Air Conditioning unit. I have removed the passenger (right) side and driver (left) side carpets and poked around under the plastic cover surrounding the heating unit inside the car in the middle below the dash. I have watched every video and searched all sites and the unit looks very different. Certainly no drain hoses.
I have tried looking under the car and can't locate any drain.
I am stumped and getting fed up.
I live in a small northern community and no one wants to deal with the problem and the manual is not helpful. I have searched the Land Rover Service Repair Manual CD and can't find any useful advice. I am a 67 year old woman and this is not what I want to be doing with my life.
Last edited by BC freelander; Aug 29, 2021 at 03:24 PM. Reason: forgot to identify A/C as the problem
Old Sep 10, 2021 | 06:32 PM
4th Gear
Just to let any other unhappy 2005 Freelander owner know - the drain hose for the A/C does not exit through the floor. The Evap unit is below the passenger (LWD) side glove box (NOT under the center of the console above the transmission as many videos show) and the drain tube exits the back of the evap unit through the carpet, sound deadening and through the bulkhead into the engine compartment. My drain hose is flexible with a tapered end at the bottom of the hose. The hose drains on to a heat deflector in the bulkhead side of the engine compartment. Some other threads say the tapered end indicates a bulkhead hose - but not on my LR. Took a lot of struggle but I took the passenger seat out, and the soaking wet carpet out (had to do some cutting so as not being forced to remove the fascia) and then cut a bigger hole in the sound deadening foam around the pipe where it enters the bulkhead (from the inside of the car). I tightened the hose up around the evap part and then I will run the A/C to see if any water leaks into the passenger floor well from the A/C unit. If all is OK, I plan to park the Freelander outside and let the rain pour down for a couple of days. If no water comes in, I will replace the carpet (with a bigger hole for the drain) and, by gum, it had better stay dry.
Chris59
Dec 7, 2020 11:51 AM
Micky1
Freelander
Jan 14, 2020 12:49 PM
rcksblr
Freelander
Dec 4, 2019 05:50 PM
G Reeves
Freelander
May 3, 2012 10:06 AM
NW_rockhound
Nov 13, 2008 09:03 PM
