freelander td4 tailgate opens when ignition is on
Hi, We have a TD4 (51 plate) freelander which has developed a problem. Recently I fitted a new rear tailgate window mechanism as the cable had corroded. All was well until today.. now when the ignition is switched on the rear window mechanism drops the window and opens the tailgate, the window mechanism then grinds and turns until the the ignition is turned off and then the door is shut, once this happens the window returns to its closed position and all is well until the ignition is turned on again, then the whole process starts again... all the interior lights come on and at night is quite off putting whilst trying to drive....... any ideas?
Thanks
Ian
Thanks
Ian
