Freelander Talk about the Land Rover Freelander within.
freelander td4 tailgate opens when ignition is on
Old Nov 28, 2010 | 02:08 PM
trophy900's Avatar
5th Gear
Default freelander td4 tailgate opens when ignition is on
Hi, We have a TD4 (51 plate) freelander which has developed a problem. Recently I fitted a new rear tailgate window mechanism as the cable had corroded. All was well until today.. now when the ignition is switched on the rear window mechanism drops the window and opens the tailgate, the window mechanism then grinds and turns until the the ignition is turned off and then the door is shut, once this happens the window returns to its closed position and all is well until the ignition is turned on again, then the whole process starts again... all the interior lights come on and at night is quite off putting whilst trying to drive....... any ideas?
Thanks
Ian
Old Nov 28, 2010 | 02:16 PM
Rovin4life's Avatar
check the wiring to the rear door for issues, also check to make sure the brake lights are all correct and not burned out.
seen weird issues with bad bulbs and the wrong ones as well.
Old Nov 28, 2010 | 03:10 PM
trophy900's Avatar
5th Gear
Thanks will give that a try as soon as the snow allows!!! Strange it started all of a sudden whilst the car was reversing!"£$!
Old Nov 30, 2010 | 11:17 AM
trophy900's Avatar
5th Gear
Sorted... water had ingressed into the electrics and was causing a short... dried out using a hairdryer and then heat shrinked over the lot!! Bloody snow I hate it.. thanks foe your help
gmca01
Freelander
Jun 7, 2012 02:03 PM
AMO123
Freelander
Jul 10, 2009 01:33 PM
Smithsmaville
Freelander
Apr 13, 2008 09:36 AM
alexg
Oct 18, 2007 03:08 AM
tonygallagher
Apr 13, 2007 01:30 PM
