Freelander Talk about the Land Rover Freelander within.
Help please! Intermittent engine smoke
Old Apr 20, 2021 | 10:02 AM
stevegantlett@btinternet.com's Avatar
6th Gear
Default Help please! Intermittent engine smoke
My 2014 Freelander 2 TD4 belches oily smoke from the engine compartment, but only very intermittently. When I open the bonnet and rev the engine I can't tell where it is coming from. Then the problem goes away for a couple of months or more, and then it comes back again. I've twice had Land Rover service the vehicle and have hoped they would pick up and cure the fault, but they haven't. Each occasion the vehicle has gone in, the fault has not been occurring. But now, for about the tenth time in two years it is back again. What is it likely to be? Should I just wait for it to go away again? If it's a gasket going, could it be serious and how can it be so intermittent?
Old Apr 22, 2021 | 07:01 PM
guy's Avatar
guy
have the turbo inspected for cracks??
Old Apr 23, 2021 | 06:05 AM
6th Gear
Many thanks. It's a plan. If it is that and it gets worse is the likely outcome a sudden breakdown on the road?
Old Apr 23, 2021 | 07:44 AM
guy's Avatar
guy
Apparently cracked turbos are a common issue. The vehicle does go into a reduced performance mode. I'm not certain you'll be stranded. Also, the LR solution is to replace the turbo, but many independant shops weld the crack.
FYI, most of us with your vehicle post in the LR2 forum and not here under "Freelander".
Old Apr 23, 2021 | 09:52 AM
6th Gear
Very many thanks, Guy
daveh
Freelander
Jan 15, 2024 10:26 AM
Shaneob
Dec 10, 2009 05:47 PM
liamys
Aug 15, 2009 07:33 AM
suveer
Jul 10, 2007 12:14 AM
bazzani
Freelander
Feb 3, 2006 10:47 AM
